I'm brand new to Infragistics so this is likely a beginner issue but here goes...
When I specify an image for a ContentPane, when the pane is hid the image appears very large.
I have tried both .ico and .png file types.
Any ideas?
Troy
FYI... I figured out the issue I mentioned in my last post where there was appearing a 'box' for an unpinned tab item. Below is a portion of the DockManagergeneric.xaml that I used to control the size of the image (which was my original problem) while trying to implement that fix I changed the Width and Height properities in the below snippet to 20 which caused the problem setting them back to 'Auto' corrected it. The 'box' I was referring to is actually the lighlihhted border for the unpinned tab.
<!-- ========== UnpinnedTabItemTemplateKey ========== -->
="true">
="Background">
="Auto">
="0,1,1,1"/>
="True"/>
I can't really say exactly what is wrong but that looks like the background/border for the tab item which in the default template is provided by the CardPanel whose name is Background. Perhaps you changed something else when you copied the template.
That did it! or i should say i finally understood it. I also had to set
Stretch
="Fill"
in addition to setting the Width and height properties, otherwise only a portion of the image would display.
It did create one GUI issue where what looks like a small box appears next to the image when a pane is unpinned. I have attached a screen shot. I have played with a few items in the ControlTemplate xaml but never made a difference. Any ideas?
quorumXSellerator said:1) So this is the area under the UnpinnedTabItemTemplateKey section fo the DockManagerGeneric.xaml file I would change the Width and Height for?
quorumXSellerator said: 2) How do I incorporate this change into my project? I'm still new to this so you have to keep it simple.
quorumXSellerator said: 3) If I'm using a different theme for my application, such as Office 2007 black, do i still use the DockManagerGeneric.xaml or the one specific to the thene i'm using or does it even matter once I move the Width/Height change into my project.
I think I know how to do this in code behind but I'd preferr to do this in the Template so i don't have to keep doing it in code behind each time I add a pane to the xamDockManager control.
igWindows:CardPanel>
Thanks, Troy
