385
Re-Setting a label value programatically throws an exception
Here is a stack trace from the exception:
All I am trying to do is :
field.Label = metadata.Label
   at Infragistics.Windows.DataPresenter.Field.get_AllowLabelVirtualizationResolved()
   at Infragistics.Windows.DataPresenter.Field.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
  • 69686
    I was not able to reproduce that with the default settings of the XamDataGrid. Can you give us more information if there is anything specific that you are doing?
