125
Getting Exception While Adding Image In XAMDatagrid
Window.Resources>
<ObjectDataProvider x:Key="MyData" ObjectType="{x:Type my:DataConnection}" MethodName="GetDataConnection" />
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="ProductImage">
<Setter Property="Template"><Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
<Grid Width="{TemplateBinding Width}" Height="{TemplateBinding Height}">
<Image Margin="{TemplateBinding Padding}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}"VerticalAlignment="{TemplateBinding VerticalContentAlignment}" Source="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}"/></Grid>
</ControlTemplate></Setter.Value> </Setter></Style>
</Window.Resources>
<Grid Name="MyLayout">
<igDP:XamDataGrid DataSource="{Binding Source={StaticResource MyData}}" Margin="12" Name="xamDataGrid1"><igDP:XamDataGrid.FieldLayoutSettings><igDP:FieldLayoutSettings AutoGenerateFields="False" /></igDP:XamDataGrid.FieldLayoutSettings><igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout><igDP:FieldLayout.Fields><igDP:Field Name="Name" Label="Name" >
<igDP:Field.Settings><igDP:FieldSettings CellMinWidth="200" CellWidth="200" />
</igDP:Field.Settings></igDP:Field><igDP:Field Name="Photo" Label="My Photo">
<igDP:Field.Settings><igDP:FieldSettings CellMinWidth="200" CellWidth="200" CellValuePresenterStyle="{StaticResource ProductImage}" /></igDP:Field.Settings></igDP:Field></igDP:FieldLayout.Fields></igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts</igDP:XamDataGrid></Grid>
Below is My XAML Code Where in I want to Display Name in First Columnfield and Image In another column. i have used Cellvaluepresenter as specified in Infragistic DOcuments..But I am getting exception  ""Error 2 Could not load type 'Microsoft.Windows.Design.Metadata.ProvideMetadataAttribute' from assembly 'Microsoft.Windows.Design.Extensibility, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'."
Kindly Help Me to solve above Exception ..Please reply
->>>>>>>>>>>>>>>Here is my XAML Code -->>>>>>>>>>
