I have a quetion concerning BINDING the width of a specifice field to a slider-value in XAML.
My grid's first field is retemplated by showing a viewbox with a specific shape in it.
On my XAML I have a slider for controlling the width of the viewbox via binding. This works perfectly and my shape in it is growing/shrinking as I move the slider.
But when my shape grows, the datagrid rows grows also --> so perfect. (shrinks also)
But my the field/column width does NOT change (grow).
I also tried to BIND the width of the field via the fieldsettings, but changes in the slider are not reflected (width of column does not change)
I tried several comibantions of the cell-label-min/max/width. But none seems to reflect to a binding at runtine.
igDP:FieldLayout.Fields>
</igDP:Field.Settings>
</igDP:Field>
<igDP:Field Name="line1" />
</igDP:FieldLayout.Fields>
and my slider
<Slider Margin="12,12,12,0" Name="slider1" Height="22" VerticalAlignment="Top" Maximum="1000" Minimum="300" SmallChange="20" LargeChange="100" Value
="450" />
I hope my question is somewhat clear. I just want a way to resize one field through a binding with a slider value at runtime. Is this possible in the grid?
Thx for the link to the post. I have read them and tried some possibilities out.
*) the staticresource and the app-resources option did work, but designing the xaml-usercontrol was not possible anymore because the staticresource is not found at design-time (same happens in the demo of Josh)
So I tried the other methods also "the spy" and "the bridge" method, but they seem to work with a dataContext property which is not settable for fieldsettings etc...
But the last option "do it in code via BindingOperations" has done the trick. I did it for the cellwidth, labelwidth en width and it WORKS !
It is indeed a pitty that something that "simple" is not just possible in xaml and my VMMV-model. I now have to write a bunch of code (and clean-up code) to do the bindings in code-behind. But that's the way it is for now.
Thanks again for pointing me out to a working solution.
This sounds like the same issue that Andrew Smith explains in this forum thread.
