I have a serious problem with customzing a XamDataGrid. I display hierarchical data within a gri, say three levels.
What I want the grid to have, is a single header at the very top that shows the columns of the third level. It is essential that the header is shown at the top of the grid, rather than at the top of each nested group.
I attached a picture that demonstrates what I want to achieve.
Any help is appreciated!
Despite the suggestion of tbeaulieu, I couldn't get the grid work the way we want. This is really sad. We will have to decline using XamDataGrid, just because it doesn't offer standard functionality out of the box.
Having a shared header for sub-groups is a crucial requirement. And I hope to get an official statement from the Infragistics guys. I'd hate to kick XamDataGrid out of our project.
Hi tbeulieu,
Thanks for your answer. This is an interesting idea you have there. It isn't exactly what I was looking for, but I will investigate your suggestion and will see how far I can get.
Perhaps there are still some other hints out there. Keep 'em coming.
I believe you're trying to do somethig similar to what I'm doing. You would do three things:
1. Hide the Labels that would normally be above the columns.
<igDP:FieldLayout.Settings>
<igDP:FieldLayoutSettings LabelLocation="Hidden" />
</igDP:FieldLayout.Settings>
<igDP:FieldLayout.Fields>
2. Create an event handler for xxx
InitializeRecord="XamDataGridDetails_InitializeRecord"
3. In the new event handler, override the GroupByRecord's Description property with a formatted string.
private void XamDataGridDetails_InitializeRecord(object sender, Infragistics.Windows.DataPresenter.Events.InitializeRecordEventArgs e){ if (e.Record != null) { GroupByRecord gbr = e.Record as GroupByRecord; if (gbr != null) { if (gbr.Value != null) gbr.Description = string.Format(" {30,0} Soll Ist", gbr.Value.ToString()); else gbr.Description = "NULL"; } }}
The catch is that I suspect you may struggle with aligning the labels over the columns, since columns can be resized and thus moved.
