I am working with multiple xamdatagrids. I have two inherited classes from xamdatagrid. I create xamdatagrid inside another xam datagrid. I have ued first inheriter to be the top grid and the second to be the child grids, since i have different functionalities for both. I can have upto 3 levels of heirarchical grds, but can have n number of top level grid. I get stack over flow exception when i click on the row of second level grid inside second top level grid. I am using observablecollections to bind the grids. I have used converters to convert values. This was working fine with infragistics.windows.datapreseter dll of 8.1 version. When i upgraded that to 9.2 i am having this problem.. When i look into the code in debug mode, i find after completing the 'LostFocus' event of the grid which i handle, it goes to read the attributes of my underlying datasource in never ending cycles. Below is an example to visualize the scenario i am talking:
1. TopLevelXamgrid1
1.1 FirstInnerXamgrid
1.1.1 SecondInnerXamgrid
2. SeconTopLevelXamgrid2
2.1 FirstInnerXamgrid
2.1.1 SeconInnerXamgrid
When i click on the row of 2.1.1 i get stackoverflow exception. When i click on 1.1.1, its fine. The same code i have is working fine with 8.1 version. Tried using usenestedpanels=true and Isnesteddatadisplayenabled=true in vain.
Immediate suggestion or solution is awaited and appreciated.
aziz
You can look at the breaking changes for 9.2 here, which may cause a failure when upgrading. If none of them addresses your issue, is it possible to provide a sample project reproducing the issue?
I am also facing same kind of issue.
Can anybody help me....
Thanks in Advance,
Arthi M
