1210
XamDataGrid Column Header Height
Hi Guys,
I have a problem with XamDataGrid column header height, in one of my controls it seems to be much higher than usual and i can't seem to be able to control it.
Can you think on anything that might cause this? This is really annoying... Is there a way to control the height of the column header? I'd like it to stay just as is but just change the height.
In this code:
        <dp:XamDataGrid Name="dataGrid" DataSource="{Binding Children}" MouseMove="XamDataGrid_MouseMove" MouseDoubleClick="XamDataGrid_MouseDoubleClick" SelectedItemsChanged="XamDataGrid_SelectedItemsChanged"
                        ContextMenu="{Binding Converter={StaticResource ContextMenuConverter}}" Theme="{Binding Theme}"
                        GroupByAreaLocation="None" AutoFit="True" HorizontalAlignment="Stretch"
                        BorderThickness="1,0,1,1" BorderBrush="{StaticResource DefaultBorderBrush}">
            <dp:XamDataGrid.FieldLayoutSettings>
                <dp:FieldLayoutSettings AutoGenerateFields="False" AllowAddNew="False" AllowDelete="False" AllowFieldMoving="No" SelectionTypeCell="None" />
            </dp:XamDataGrid.FieldLayoutSettings>
            <dp:XamDataGrid.FieldLayouts>
                <dp:FieldLayout x:Name="fieldLayout">
                    <dp:Field Name="C1"/>
                    <dp:Field Name="C2"       />
                    <dp:Field Name="C3"      />
                    <dp:Field Name="C4"   />
                    <dp:Field Name="C5"    />
                </dp:FieldLayout>
            </dp:XamDataGrid.FieldLayouts>
        </dp:XamDataGrid>
The column header is too high, while in this code it is just fine:
                        <my:XamDataGrid Grid.Row="7" Margin="5,0,10,0" Grid.Column="0" Grid.ColumnSpan="3" DataSource="{Binding Path=LineItemVersionAttributes}" IsNestedDataDisplayEnabled="False" AutoFit="True" GroupByAreaLocation="None" HorizontalAlignment="Stretch" Theme="Office2k7Silver">
                            <my:XamDataGrid.FieldLayoutSettings>
                                <my:FieldLayoutSettings AllowAddNew="False" AllowDelete="False" AllowFieldMoving="No"/>
                            </my:XamDataGrid.FieldLayoutSettings>
                            <my:XamDataGrid.FieldLayouts>
                                <my:FieldLayout>
                                    <my:Field Name="Name" Visibility="Visible" Width="150"/>
                                    <my:Field Name="Value" Visibility="Visible" Width="120"/>
                                    <my:Field Name="Units" Visibility="Visible" Width="120"/>
                                    <my:Field Name="Description" Visibility="Visible" Width="*"/>
                                </my:FieldLayout>
                            </my:XamDataGrid.FieldLayouts>
                            <my:XamDataGrid.FieldSettings>
                                <my:FieldSettings AllowEdit="False" AllowRecordFiltering="True" ExpandableFieldRecordExpansionMode="ExpandAlways"/>
                            </my:XamDataGrid.FieldSettings>
                        </my:XamDataGrid>
What am i doing wrong here? Pls help....
Thanx,
Gili
