1405
Enable/disable buttons from the XamRibbon problem
Hello.
I have a problem regarding enable/disable buttons from the XamRibbon.
The buttons from the XamRibbon from my application are bounded to commands. When a command can/can't be executed, the buttons will be enabled/disabled. This works fine. The only problem is that when I load the application the first time, the button's images that are disabled have some black border.
I have attached a screen shot of this. Do you know if I can do something to change this behaviour?
I am using Infragistics 2009 vol.2 for the tests and Windows Vista.
Thanks very much for help.
Nico
  • 1405
    I have tried this also with the hotfix SR_2049 and the problem is still there.
    Can you please help me?
    Thanks.
    Nico
