The ValueConstraint.MaxLength needs to be data bound. I have tried using DataBinding and it is not working, though I can use the exact same Binding statement at the same level and get the correct value.
I posted a question in the MSDN forum and they did not see anything wrong with the code, they did state that the MaxLength needs to be a dependency property of a Framework element...
Here is the code:
<igEditors:XamTextEditor Margin="8,1" Text="{Binding Answer, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" Visibility="{Binding ResponseParam, Converter={StaticResource EditorVisibilityConverter}, Mode=OneWay}" > <!-- This does NOT work --> <igEditors:XamTextEditor.ValueConstraint> <igEditors:ValueConstraint MaxLength="{Binding ResponseParam.MaxLength, Mode=OneWay}" /> </igEditors:XamTextEditor.ValueConstraint> <igEditors:XamTextEditor.ToolTip> <WrapPanel> <StackPanel Orientation="Horizontal"> <TextBlock Text="Maximum Length: " FontWeight="Bold"/> <!-- This works JUST fine --> <TextBlock Text="{Binding ResponseParam.MaxLength, Mode=OneWay}"/> </StackPanel> </WrapPanel> </igEditors:XamTextEditor.ToolTip> </igEditors:XamTextEditor>
Margin="8,1"
<WrapPanel>
</StackPanel>
</WrapPanel>
That is correct, the ValueConstraint is not an element in the visual tree of the application and cannot be data bound. What you can do, is create a converter (IValueConverter) that will return a ValueConstraint object. Then you can apply the binding at the ValueConstraint property with the converter.
Hope this helps.
