Hello.
I'm using the xamDataGrid with a DataTable as datasource. The tables rows and columns define their own errors and I use DataErrorDisplayMode = DataErrorDisplayMode.Highlight to visualize the errors. And it works fine! The cells with errors are highlighted. But the highlight color is kind of a strange shade of pink. Is there any way to change the color? Or set up my own Style for cells with errors?
Sorry, my mistake. I was viewing the 9.1 version. I hadn't changed my shortcut after installing 9.2. I will check the samples now.
Thank you for all your help in all my threads.
Are you by any chance looking at the 9.1 Feature Browser? Please note that this feature in only available in volume 9.2, so you should open the XFB for 9.2
Has this recently been added? I can't find it in my xamFeatureBrowser.
You can find a sample for this in the XamFeatureBrowser, which is installed with our products. The sample is under XamDataGrid - Themes and Custom Styles = Data Error Styling
