220
Gestures Not Responding on XAMRibbon
I have run the sample XamRibbonWindow, and when I press the Alt key, letters show up above the menu, and I can then key the letter (ie "F" for the ApplicationMenu) and navigate to that menu using key gestures.  However with the code below, this doesn't occur.  Anything that I have missed?   Thank you
<igRibbon:XamRibbonWindow x:Class="StdWinGUI.Common.frmTestWPF"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:igRibbon="http://infragistics.com/Ribbon"
    xmlns:std="clr-namespace:StdWinGUI.Common"
    Title="frmTestWPF" Height="312" Width="419">
    <igRibbon:RibbonWindowContentHost>
        <igRibbon:RibbonWindowContentHost.Ribbon>
            <igRibbon:XamRibbon
                        HorizontalAlignment="Stretch"
                        VerticalAlignment="Stretch"
                        DockPanel.Dock="Top"  >
                <igRibbon:XamRibbon.ApplicationMenu>
                    <igRibbon:ApplicationMenu>
                        <igRibbon:ToolMenuItem Header="_Close"></igRibbon:ToolMenuItem>
                    </igRibbon:ApplicationMenu>
                </igRibbon:XamRibbon.ApplicationMenu>
                    <igRibbon:XamRibbon.Tabs>
                    <igRibbon:RibbonTabItem Header="Help" >
                        <igRibbon:RibbonGroup Caption="Help">
                            <igRibbon:ButtonTool Caption="Help" />
                        </igRibbon:RibbonGroup>
                    </igRibbon:RibbonTabItem>
                </igRibbon:XamRibbon.Tabs>
            </igRibbon:XamRibbon>
        </igRibbon:RibbonWindowContentHost.Ribbon >
        <igRibbon:RibbonWindowContentHost.StatusBar>
            <StatusBar HorizontalAlignment="Stretch"
                               DockPanel.Dock="Bottom"
                               Height="23" >
                <StatusBarItem Name="_SbiStatus"
                                       Content="Ready" />
            </StatusBar>
        </igRibbon:RibbonWindowContentHost.StatusBar>
        <ContentPresenter />
    </igRibbon:RibbonWindowContentHost>
</igRibbon:XamRibbonWindow>
  • 220
    Some further investigation led to some more clues, but no solution, hopefully someone can provide some help.
    If I take the exact same code, and put into a new WPF Application project, the gestures work.
    In it's existing situation the code is in a WPF Class Library that contains both Windows forms and WPF Windows like the one above.  The test form above is being called from a Windows form calling the WPF Window.Show method.  I would like to keep it in a mixed project, but not sure if this is possible.  All suggestions appreciated.  Thank you,
    Mike
