I want to export grid to excel as it is shown. For example, there is a combo on a field and the valuepath and the displaymemberpath are different from each other. If I export the grid to excel the valuepath values is shown on the excel sheet. I want to export the grid with the displaymemberpath values, not with the valuepath values. How can i do that?
<igDP:Field Name="bbbb" Label="aaaa"> <igDP:Field.Settings> <igDP:FieldSettings EditorType="{x:Type inf:XamComboEditor}" AutoSizeOptions="All"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type inf:XamComboEditor}"> <Setter Property="DisplayMemberPath" Value="Value" /> <Setter Property="ValuePath" Value="Code" /> <Setter Property="Value" Value="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}" /> <Setter Property="ItemsSource" Value="{Binding RelativeSource={RelativeSource AncestorType={x:Type local:DCDList}},Path=DataContext.CurrencyList, Mode=OneWay}" /> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
Hello again,
I tried your suggestion but that does not work:
private void ExcelExporter_CellExported(object sender, CellExportedEventArgs e)
e.CurrentWorksheet.Rows[e.CurrentRowIndex].Cells[e.CurrentColumnIndex].Value = e.Record.GetCellText(e.Field);
I need to catch XamComboEditor in the cell that is in CellExportedEventArgs (e), or directly the text value of xamComboEditor. Any suggestions?
Which is the exact build version of our controls are you using?
Please also follow the following forum thread :
http://community.infragistics.com/forums/p/33293/181481.aspx#181481
