Good day
I dont know if you are aware of the problem, but your online help does not seem to work nicely for the wpf section.
The content pane does not provide a scroll bar when it grows past the screen when expanding the tree.
On the 2009.2 page (http://help.infragistics.com/NetAdvantage/WPF/2009.2/CLR3.5/) most of the links does not open the page required (not even in new pane). It works fine for 2009.1.
I'm using firefox 3.5.3 and have not tested it in other browsers.
Hope this helps.
Kind regards
Thank you Tom
It is not that big issue for me, just thought I would let you know.
Christo
Hi Chris, Sorry for the inconvenience, this is a known issue with FF. We are currently working on a newer version of the Help application. The workaround for this would be to use IE until we deploy the new version.
