275
CellWidth can't be set to a low value
The following code snippet is from the FieldLayoutInitialized handler of a XamDataGrid. Setting the CellWidth to 250 works fine (case "abc"), but setting it to 20 doesn't (case "def"), even if I am setting the CellMinWidth to the same value. It looks like the minimum width I can can set it to is around 60 (for this particular grid). Is there any other setting that prevents the CellWidth to go below a certain value?
            foreach (var field in e.FieldLayout.Fields)
                switch (field.Name.ToLower())
                    case "abc":
                        field.Settings.CellWidth = 250;
                        break;
                    default:
                        field.Settings.CellMinWidth = 20;
                        field.Settings.CellWidth = 20;
                        break;
  • 275
    Verified Answer
    Answering my own question: It's the LabelWidth that was preventing the CellWidth to go below a certain value. Problem resolved by setting LabelWidth = CellWidth.
