280
ComboBox in Floating pane isn't working
I have a DockContentHost which contains a split pane which contains a tab pane which contains a content pane.  Inside this content pane I just have a combobox connected to an observable string collection.
1. When the content pane is loaded up normally the combobox works as expected.  If i drag the pane out of the ContentHost and use the DocManager_ToolWindowLoaded event to set e.Window.UseOSNonClientArea = false, the combobox no longer 'drops down'.
2. When the content pane is loaded up normally the combobox works as expected.  If i drag the pane out of the ContentHost WITHOUT setting e.Window.UseOSNonClientArea = false, the combobox works as intended.  What am I missing?
