805
Discrepancy in XamDataGrid binding when Explicit Interface is used
I have a scenario where I have to implement interface explicitly. I have simplified the case with the following code:
public interface IText
      string Text { get; set; }
public class MyText : IText
      public int Text { get; set; }
      string IText.Text{ get; set; }
      public MyText()
            Text = 1;
            ((IText)this).Text = "Text";
I have to bind list of IText  data in XamDataGrid:
List<IText> list = new List<IText>();
list.Add(new MyText());
xamDataGrid.DataSource = list;
I was expecting XamDataGrid would bind "Text" but it is showing "1" in the rows. Besides, I used similar case for a Console application with the following statements and it shows "Text" in the console.
foreach (var item in list)
      Console.WriteLine(item.Text);
Am I missing something or do I have to provide additional statements in order to have the data bind with string Text instead of int Text?
Balaji Rajendran
CCH, WK - Torrance, CA
  • 69686
    Hello Balaji,
    The XamDataGrid creates Fields only for the public properties of the underlying class. I believe that your (string) Text property is private if you do not set an access modifier.
