i´m using the XamNumericEditor. I´m using DataBinding to a property of type int32. I would like to build something like this:
If the value int32=0, the XamNumericEditor should show an empty editor. How can i do that with XamNumericEdior?
With best regards from Germany
Christian
Hello Christian,
For this, you can use ValueToDisplayTextConverter property. You have to create a class that implements the IValueConverter interface and return an empty string when the value is 0. Let me know if you need further assistance with this matter.
