I have a hierarchical data grid, bound to a collection, which has a list as one of it's member.
I set the DataRecordCellAreaGridTemplate property for the normal data rows, but I can find a way to apply it separately to the hierarchical row, which presents the list member.
This is an example of a code like mine:
<igDP:XamDataGrid Name="SampleDataGrid" GroupByAreaLocation="None" AutoFit="True"> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoGenerateFields="False" > <igDP:FieldLayoutSettings.DataRecordCellAreaGridTemplate> <ItemsPanelTemplate> <Grid> <Grid.ColumnDefinitions> <ColumnDefinition Width="Auto" /> <ColumnDefinition Width="Auto" /> </Grid.ColumnDefinitions> </Grid> </ItemsPanelTemplate> </igDP:FieldLayoutSettings.DataRecordCellAreaGridTemplate> </igDP:FieldLayoutSettings> </igDP:XamDataGrid.FieldLayoutSettings> <igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:Field Name="OfficeName" Label="OfficeName" /> <igDP:Field Name="OfficeAdress" Label="OfficeAdress" /> <igDP:Field Name="List" Label="List" /> </igDP:FieldLayout> <igDP:FieldLayout> <igDP:Field Name="Id" Label="Id" /> <igDP:Field Name="Name" Label="Name" /> </igDP:FieldLayout> </igDP:XamDataGrid.FieldLayouts> </igDP:XamDataGrid>
Thanks in advace.
As you are using XamDataGrid.FieldLayoutSettings, they will be applied to all of the fieldlayouts.
You can however specify this per FieldLayout by setting its Settings , i.e. FieldLayout.Settings.
Please note that fields also expose LabelWidht / CellWidth,etc. properties
