Hello. I have a problem with the QuickAccessToolbar.
I have downloaded the XamRibbon from the internet and I want to use it in a Wpf application. But I need to customize that XamRibbon so I created a user control derived from the XamRibbon and I added on it some buttons and some labels. Some of the buttons I have added them on the QuickAccessToolbar, like this: QatPlaceholderTool TargetId="button1". I created then a XamRibbonWindow and for that window I specified the ribbon of the RibbonWindowContentHost as the control that I created.
But the buttons from the QuickAccessToolbar are not visibles. I copied the code from my control on a XamRibbonWindow and it works. But when I use my control, I have on the QuickAccessToolbar only empty spaces.
Please can you help me with this problem.
Thanks.
Nico
Hello. I got the hotfix for this problem and now it's working.
Thanks very much for help.
I looked at the snippet and was able to see the problem. This is a bug in the control and will be addressed in a hotfix. Please report the issue to the support group so that you can be notified when the fix is available. http://ko.infragistics.com/gethelp/default.aspx
When reporting the issue, please reference issue # BR31021.
Thanks for the quick response. Here is the ribbon:
<infragisticsRibbon:XamRibbon x:Class="WpfPaMaPrototype.UserControls.Navigation.userControlRibbon"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:Microsoft_Windows_Themes="clr-namespace:Microsoft.Windows.Themes;assembly=PresentationFramework.Aero"
xmlns:infragisticsRibbon="clr-namespace:Infragistics.Windows.Ribbon;assembly=Infragistics3.Wpf.Ribbon.v7.2" Width="Auto" Height="auto">
<infragisticsRibbon:XamRibbon.QuickAccessToolbar>
<infragisticsRibbon:QuickAccessToolbar>
<infragisticsRibbon:QatPlaceholderTool TargetId="button1" />
<infragisticsRibbon:QatPlaceholderTool TargetId="button2" />
<infragisticsRibbon:QatPlaceholderTool TargetId="button3" />
</infragisticsRibbon:QuickAccessToolbar>
</infragisticsRibbon:XamRibbon.QuickAccessToolbar>
<infragisticsRibbon:RibbonTabItem Name="rtiPartner" Header="Partner" Height="auto">
<infragisticsRibbon:RibbonGroup Name="rgrPartner" Caption="Partner">
<infragisticsRibbon:ToolVerticalWrapPanel>
<infragisticsRibbon:ButtonTool Height="23" Id="button1" Name="button1" Width="23" Caption="" LargeImage="/WpfPaMaPrototype;component/Resources/Icons/help.png" Click="button1_Click" />
</infragisticsRibbon:ToolVerticalWrapPanel>
</infragisticsRibbon:RibbonGroup>
<infragisticsRibbon:RibbonGroup Id="rgrPartnerdaten" Caption="Partnerdaten">
<infragisticsRibbon:ButtonTool Height="23" Id="button2" Name="button2" Width="23" Caption="" LargeImage="/WpfPaMaPrototype;component/Resources/Icons/help.png" Click="button2_Click" />
<infragisticsRibbon:ButtonTool Height="23" Id="button3" Name="button3" Width="23" Caption="" LargeImage="/WpfPaMaPrototype;component/Resources/Icons/help.png" Click="button3_Click" />
</infragisticsRibbon:XamRibbon>
And here is the window:
<infragisticsRibbon:XamRibbonWindow x:Class="WpfPaMaPrototype.winPaMa"
Title="LKW - Walter (PaMa)" WindowState="Maximized" Icon="Resources/Icons/MainMenuPartner.png"
xmlns:userControlsNavigation="clr-namespace:WpfPaMaPrototype.UserControls.Navigation" Height="676" Width="1132" >
<infragisticsRibbon:RibbonWindowContentHost>
<infragisticsRibbon:RibbonWindowContentHost.Ribbon>
<userControlsNavigation:userControlRibbon x:Name="userControlRibbon"/>
</infragisticsRibbon:RibbonWindowContentHost.Ribbon>
</infragisticsRibbon:XamRibbonWindow>
Thanks for the quick answer.
Here is the ribbon I created:
And here is the window where I use it:
