470
Cell Value not showing when bind with DataTable
I have a DataTatble with a DataColumn defined as
DataTable dt = new DataTable();
            DataColumn dcPrice = new DataColumn("Price");
            dcPrice.DataType = typeof(decimal);
            dcPrice.DefaultValue = 54;
            dt.Columns.Add(dcPrice);
I am binding it with XamDataGrid using
Xamgrid.DataSource = dt.Rows
The code in XAML is
<igDP:Field Name="Price" Label="TaxCode" >
<igDP:Field.Settings>
            <igDP:FieldSettings />
      </igDP:Field.Settings>
</igDP:Field>
Which is working fine but if I use unbooundfield like below
<igDP:UnboundField Name="Price" Label="Price" BindingPath="Price">
<igDP:UnboundField.Settings>
      </igDP:UnboundField.Settings>
</igDP:UnboundField>
Or
      <igDP:FieldSettings CellValuePresenterStyle="{StaticResource PriceCellStyle}"  />
//Where PriceCellStyle is defined in Resources as
        <Style x:Key="PriceCellStyle" TargetType="{x:Type igDP:CellValuePresenter}">
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                        <StackPanel x:Name="stackPanel" Orientation="Horizontal">
                            <TextBox Text="{Binding Path=DataItem.Price}" ></TextBox>
                        </StackPanel>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
Its not showing the values then
I need to show TextBox in the grid binded with the “Price” column as defined in the datatable
Thanks in Advance,
Rehman Mansoor
