Hi
Please consider the following:
<igDP:Field Name="Name" Label="{Binding Path=ModeAlt, Mode=OneWay, PresentationTraceSources.TraceLevel=High}">
<igDP:Field.Settings>
<igDP:FieldSettings AllowEdit="False" AllowGroupBy="False" AllowResize="True" CellClickAction="SelectRecord" />
</igDP:Field.Settings>
</igDP:Field>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
When the above code is used, I get a binding error in me immediates window saying:
Cannot find governing FrameworkElement or FrameworkContentElement for target element
Has anyone successfully bound a DtaPresenter Field.Label to a dependency property?
PS.. this forum is still nasty as anything for pasting code... so much for pleasent user experiences! :o)
Sorry for the double post but the code didn't format in the last
post...
private void UpdateLabels() { Infragistics.Windows.Utilities.GetDescendantFromType
<LabelPresenter>(AllocationsGrid, false, new
.DependencyObjectSearchCallback
<LabelPresenter>(DescendentCallback)); } private bool DescendentCallback(LabelPresenter target) { TextBlock textBlock = Infragistics.Windows.Utilities.
GetDescendantFromType(target, typeof(TextBlock), false)
as TextBlock; if (textBlock != null) { //get the labelPresenter you want to modify
based on a unique
value (you could set the Tag property in xaml). if (target.Tag == "SomeUniqueProperty") { //set the label to whatever you want here textBlock.Text = "New Label Name"; //breaks the descendent callback recursion return true; } } return false; } private void MyGrid_LayoutUpdated(object sender, EventArgs e) { UpdateLabels(); } private void MyPage_Loaded() { UpdateLabels(); }
You can access the TextBlock inside the LabelPresenter and modify it using code with the example below. In my opinion this is a terrible hack, but as an earlier post states the grid was not architected for binding because the fields don't exist in the visual tree. Hope this helps.
Infragistics.Windows.Utilities.GetDescendantFromType<LabelPresenter>(AllocationsGrid, false, new Infragistics.Windows.Utilities.DependencyObjectSearchCallback<LabelPresenter>(DescendentCallback)); }
private bool DescendentCallback(LabelPresenter target) { TextBlock textBlock = Infragistics.Windows.Utilities.GetDescendantFromType(target, typeof(TextBlock), false) as TextBlock; if (textBlock != null) { //get the labelPresenter you want to modify based on a unique value (you could set the Tag property in xaml). if (target.Tag == "SomeUniqueProperty") { textBlock.Text = "New Label Name"; return true; //breaks the descendent callback recursion } } return false; } You may also need to hook into the grids "LayoutUpdated" event and also call your UpdateLabels() method so the grid won't overwrite your changes.private void MyGrid_LayoutUpdated(object sender, EventArgs e) { UpdateLabels(); }
return false;
{ UpdateLabels(); }
That's fine for when you are creating a viewmodel within the user interface constructor, but if the datacontext is null at that point, how do you change a grids column label text dynamically/programmatically? (it does not necessarily have to be via binding)
<igDP:Field Name="CodeName" Label="Code" Width="Auto" />
I want the text in the label to be dynamic depending on a value in the viewmodel ("xxx Code")
Thanks for the link - my binding attempts in hindsight were possibly an over engineered solution for what I was attempting to achieve, but useful info none-the-less.
Paul
Fields are not part of the visual tree of the XamDataGrid so you cannot bind their properties. However, you can see how to go around this here:
http://blogs.infragistics.com/blogs/josh_smith/archive/2008/06/06/binding-a-xamdatagrid-field-property.aspx
