I would like to bind a .NET Image directly in xamDataGrid
I use a object user like this one:
public string user;
public string pass;
public Image image;
When I set my grid.datasource, the image is always empy.
Can you help me?
Alex,
I can't to embed an .Net Image in the XamDataGrid. But if I bind my image with a path (c:\test.bmp") it will visible. When I bind my Image on Textbox, I see System.Drawing.Image.
Do you have a solution for this situation?
I have the same probleme when I would like to use the control ImageBrush in a WPF UserControl.
Thank you
If you are looking for a way to embed an image in the XamDataGrid, please take a look at the samples in the XamFeatureBrowser, which in installed with our product. The sample is under XamDataGrid - Themes and Custom Styles
