190
FieldChooser - Checking columns causes order to change within FieldChooser
Please run the attached sample app.
Scenario:
FieldChooser
- Check column "Actual Jan 2009"
- Check column "Actual Feb 2009" (column immediately below "Actual Jan 2009")
Version 9.2.20092.1007
- Works as expected, both columns stay in same position in FieldChooser
Version 9.2.20092.2023 OR 9.2.20092.2049
- Column "Actual Feb 2009" moves up to where "Actual Jan 2009" was
- Column "Actual Jan 2009" moves down to below the last "Actual..." column
(Note: there is an Actual column for each month, so it moves below "Actual Dec 2009")
FieldChooserIssue.zip
