I have the following errors mentioned in the deboug-output window when i run my application:
Remark: I only get this error when i run on Vista Businnes (Dutch), and I don't get it when running same on Windows XP SP3 (Dutch)...
System.Windows.Data Error: 22 : Cannot convert '32' from type 'Double' to type 'Infragistics.Windows.DataPresenter.FieldLength' for 'en-US' culture with default conversions; consider using Converter property of Binding. NotSupportedException:'System.NotSupportedException: FieldLengthConverter kan niet van System.Double worden geconverteerd. bij System.ComponentModel.TypeConverter.GetConvertFromException(Object value) bij System.ComponentModel.TypeConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value) bij Infragistics.Windows.DataPresenter.FieldLengthConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value) bij MS.Internal.Data.DefaultValueConverter.ConvertHelper(Object o, Type destinationType, DependencyObject targetElement, CultureInfo culture, Boolean isForward)'System.Windows.Data Error: 6 : 'TargetDefaultValueConverter' converter failed to convert value '32' (type 'Double'); fallback value will be used, if available. BindingExpression:Path=ThumbnailSize; DataItem='Library_Geometry_ViewModel' (HashCode=30567910); target element is 'Field' (HashCode=6675738); target property is 'Width' (type 'Nullable`1') NotSupportedException:'System.NotSupportedException: FieldLengthConverter kan niet van System.Double worden geconverteerd. bij MS.Internal.Data.DefaultValueConverter.ConvertHelper(Object o, Type destinationType, DependencyObject targetElement, CultureInfo culture, Boolean isForward) bij MS.Internal.Data.TargetDefaultValueConverter.Convert(Object o, Type type, Object parameter, CultureInfo culture) bij System.Windows.Data.BindingExpression.ConvertHelper(IValueConverter converter, Object value, Type targetType, Object parameter, CultureInfo culture)'
I setup the binding in code (purpose is a dynamic column-with) depending on dynamic-value in model.
Remark: the solution itself works, but I was wondering why i get "errors" when running on Vista
//Setup Binding: tmpBindingThumbnailSize Binding tmpBindingThumbnailSize = new Binding("ThumbnailSize"); tmpBindingThumbnailSize.Source = this.XAML_iLibrary_Geometry_ViewModel;
//Set binding: tmpBindingThumbnailSize BindingOperations.SetBinding(tmpFieldThumbnail, Infragistics.Windows.DataPresenter.Field.WidthProperty, tmpBindingThumbnailSize);
Infragistics.Windows.DataPresenter.FieldSettings tmpFieldThumbnailSettings = null; tmpFieldThumbnailSettings = tmpFieldThumbnail.Settings;
BindingOperations.SetBinding(tmpFieldThumbnailSettings, Infragistics.Windows.DataPresenter.FieldSettings.CellWidthProperty, tmpBindingThumbnailSize);
BindingOperations.SetBinding(tmpFieldThumbnailSettings, Infragistics.Windows.DataPresenter.FieldSettings.LabelWidthProperty, tmpBindingThumbnailSize);
BindingOperations.SetBinding(tmpFieldThumbnailSettings, Infragistics.Windows.DataPresenter.FieldSettings.WidthProperty, tmpBindingThumbnailSize);
I have created a support ticket on your behalf from this forum thread with number: CAS-41497-IHNNLV . I'll make sure you are notified for the case's progress.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
This looks like a bug in the FieldLengthConverter. I've submitted the issue and we will see about getting a case created for you for this issue.
