615
XamComboEditor in specific cells
Hello!
In our grid there are some cells that need to be combos when editing. Only for a view cells, not for the whole field (column). I found out that setting EditorType and especially the EditorStyle (that includes databinding for the combo) in the InitializeRecord event handler slows down performance of the grid. Because of that I tried setting the EditorStyle in the CellActivating handler. My hope was that I could speed up the grid when setting the databinding for the combo only if needed. But the dropdown list is not filled with items.
Is there a way to set drop down list items only if they are needed? Or any other way to speed up the grid, when having combos in the grid?
thanks,
Florian
  • 9694
    The following post addresses performance and using the XamComboEditor in the XamDataGrid.The post shows an example how to use the XamComboEditor in the data grid.
    http://news.infragistics.com/forums/p/20868/75313.aspx
    Does this help with your issue?
  • 615
    I am still think about the problem how to set the XamComboEditor for specific cells. Maybe a solution might be to use a EditorStyleSelctor object that choses the right editor style from a property in the datasource of the row. Is this possible? And if yes, how?
    The important thing is the performance. I think no matter how to set the style for that combo, the performance might suffer anyway. But I don't know why and how to avoid those perfromance issues.
    thanks,
    Florian
