70
How to update bound property for checkbox column without needing to click outside cell?
I have a XamDatagrid with only one fields editable, which is a checkbox used for selecting items. When I change the value, the underlying bound property is not being updated until I click outside the cell. I tried playing with the grid's UpdateMode property but of no use.
This is very important as user click on the checkbox, they see it as the row is selected but when they perform an operation "Say delete", from the ribbon, which is supposed to delete the row.. is not being deleted. I tried to explain to users how it works.. but .. you know they are users.
Any help in this direction is appreciated.
thanks
Bhuvan
  • 385
    One of the posts suggested that you change the template to use a regular check box instead of the XamCheckBoxEditor:
    ig:Field Name="SomeBooleanField" >
    <ig:Field.Settings>
    ig:FieldSettings>
    ig:FieldSettings.CellValuePresenterStyle>
    <Style TargetType="{x:Type ig:CellValuePresenter}">
    Setter Property="Template">
    Setter.Value>
    ControlTemplate>
    CheckBox HorizontalAlignment="Center" VerticalAlignment="Center"
    IsChecked="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}"/>
    ControlTemplate>
    </Setter.Value>
    </Setter>
    Style >
    ig:FieldSettings>
    </ig:Field.Settings>
    </ig:Field>
  • 70
    Verified Answer
    Found the answer with the help of Support chat
    in the form/usercontrol constructor I had to register value changed event.
    EventManager.RegisterClassHandler(typeof(XamCheckEditor), XamCheckEditor.ValueChangedEvent, new RoutedPropertyChangedEventHandler<object>(xamDataGridCheckChanged));
    and define the event handler to force update by calling EndEditMode
    void xamDataGridCheckChanged(object sender, RoutedPropertyChangedEventArgs<object> e)
                if (sender is XamCheckEditor)
                    ((XamCheckEditor)sender).EndEditMode(true, true);
