75
Reading custom checkbox field value
Hi - ,
We are able to bind cuatom check box field in xamdatagrid..Hence we are not able to read the values if it is checked or not..
if any using checkbox in grid for binding & reading values..Please give as sample..
MK
  • 8576
    Hi MK -
    If your Field is a boolean Field then the XamDataGrid will automatically use a XamCheckEditor to display/edit the Field.  Is there any reason why this default scenario which automatically uses a XamCheckEditor will not work for you?
    Joe
