220
how to access Field's index in LabelPresenter's style?
hi guys ,
I am trying to implement different column styles in a XamDataGrid . For example : column 0 is in styleA column 1 is in style2 and the columns are auto-generated .I want to set different Template for LabelPresenter with trigger in style .  see the xaml below :
        <Style x:Key="MYSTL" TargetType="{x:Type igDP:LabelPresenter}" >
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="{x:Type igDP:LabelPresenter}">
                        <Grid>
                            <ContentPresenter HorizontalAlignment="Center" VerticalAlignment="Center"/>
                            <Button Width="15" Height="15" x:Name="btnCol" HorizontalAlignment="Left" Content="X" >
                            </Button>
                        </Grid>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
            <Style.Triggers>
                <Trigger Property="here i want to get the index of the field" Value="0">
                <Setter.Value>
                        <Grid>
                        </Grid>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
                </Trigger>
            </Style.Triggers>
        </Style>
Ethan
  • 69686
    Verified Answer
    Hello Ethan,
    The Trigger will not allow you to create such a binding. You have to use a DataTrigger for this purpose and set its binding property. Set the RelativeSource to Self and the Path to Field.Index.
    Another way would be to createa a style and set it explicitly to that field from the Field's Settings ->LabelPresenterStyle.
