340
Can I input a 2D string array into a grid?
I want a easy way to input a 2D string array(string[ , ]) in  a grid. And then set the column header.
Is it possible?
  • 2515
    I see it's too late for a reply, but a lot of people are looking at this post, so I'll attach the workaround I found.
    Basically the solution is to generate dynamic class and to insert the data from the array in new list. Then you just have to bind it.
    The attached project is for WinForms, but the same idea will work for SL and WPF.
    Best,
    George
    TwoDimensionalArrayToGrid.zip
