195
How to bind chart tooltip with legend?
I am using a DataTemplate for LegendItemTemplate which shows some text and tooltip using a converter and it is working fine.
I also show ToolTip on chart using following code:
 <igCA:Series DataPointColor="Different" Focusable="False" DataSource="{Binding Source={StaticResource DsMembershipData}, Mode=OneWay}" DataMapping="Label=SUBSCRIPTIONTYPE; Value=NOS; ToolTip=SUBSCRIPTIONTYPE" ChartType="Pie">
The ToolTip on the chart is not properly formatted as it is just binding to a value and I need a properly formatted ToolTip as shown in the Legend. Is it possible to bind the ToolTip on chart with Legend?
Thanks.
  • 9836
    In order to  format the tooltips you can set the ToolTip for each datapoint using String.Format or better use this approach to create a custom template and then set the StringFormat in the TextBlock's definition.
