When using a custom CellValuePresenter style on my grid, the edit events, and tab functions have all stopped working. The custom style is working as expected, but has lost its default events.
Help !
The style is as follows:
<Style x:Key="cellValidationStyle" TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}"> <StackPanel> <Grid Width="Auto" Height="Auto"> <!--<TextBox Text="{Binding Path=Value, Mode=TwoWay, RelativeSource={RelativeSource TemplatedParent}}" Margin="5,0,139,12" Width="Auto" Height="Auto" MinWidth="300"/>--> <igEditors:XamTextEditor Value="{Binding Path=Value, Mode=TwoWay, RelativeSource={RelativeSource TemplatedParent}}"/> <Image x:Name="ErrorIcon" Height="15" Source="erricon.gif" Visibility="Hidden" VerticalAlignment="Top" RenderTransformOrigin="7.776,0.215" HorizontalAlignment="Right" Margin="0,1.852,120.175,0" Width="15"/> </Grid> </StackPanel> <ControlTemplate.Triggers> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record, Converter={StaticResource validationErrorConverter}}" Value="False">
<Setter Property="Visibility" TargetName="ErrorIcon" Value="Visible" /> </DataTrigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> </Style>
Hi
Is there a good way of finding out what Names / current Styles are used so we can extend the Style and work with the Grid.
I have looked in the directory below but only found this under Express.
C:\Program Files (x86)\Infragistics\NetAdvantage for WPF 2008 Vol. 2\DefaultStyles
thanks
Martin
