When the records number become zero from non-zero, the event won't be raised.
I filter the records in grid by recordfilter. When the number of record become zero, I won't get the event.
I am running into the same problem. Is there a solution to this problem?
We have considered this as an issue. I am going to create a support case on your behalf so that you will be notified when this is resolved.
I use 2010 wpf grid
