605
AllowEdit only at new Rows
i would like to customize a colum of my Grid. If i set AllowEdit in the FieldSettings the whole colum is ReadOnly.
I would like to allow Edit for new Rows but not for existing ones. So i tried to trigger the EditModeStarting event for the colum but the Code doesn't execute.
Here is the Code for the Colum and its Resources:
                  <Style x:Key="FahrzeugartFieldStyle" TargetType="{x:Type igDE:XamComboEditor}">
                    <EventSetter Event="EditModeStarting" Handler="FZArtSelectedItemChanged"/>
                    <Setter Property="ValuePath" Value="FA_ID" />
                    <Setter Property="DisplayMemberPath" Value="FA_Bezeichnung" />
                    <Setter Property="ItemsSource" Value="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType=src:BASE},Path=_CRM.FAHRZEUG_ART, Mode=OneWay}" />
                </Style>
                        <igDP:Field Name="FZ_FA_ID" Label="Fahrzeugart" Width="120">
                            <igDP:Field.Settings>
                                <igDP:FieldSettings EditorStyle="{StaticResource FahrzeugartFieldStyle}" />
                            </igDP:Field.Settings>
                        </igDP:Field>
Thank you for your support.
