I am creating a dynamic context menu for a XamDataGrid. I need to know what column the cell they are right clicking on is in. Here is Xaml And Code Behind...
<igDP:XamDataGrid x:Name="XamDataGrid1"
DataSource="{Binding Model.QueryResults}"
Background="Transparent"
Theme="Office2k7Black">
<igDP:XamDataGrid.Resources>
<Style TargetType="{x:Type igDP:DataRecordCellArea}" >
<EventSetter Event="ContextMenu.ContextMenuOpening" Handler="cm_ContextMenuOpening"></EventSetter>
<Setter Property="ContextMenu">
<Setter.Value>
<StaticResourceExtension ResourceKey="cmenu"></StaticResourceExtension>
</Setter.Value>
</Setter>
</Style>
</igDP:XamDataGrid.Resources>
<igDP:XamDataGrid.FieldSettings>
<igDP:FieldSettings AllowEdit="False" />
</igDP:XamDataGrid.FieldSettings>
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings HighlightAlternateRecords="True"/>
</igDP:XamDataGrid.FieldLayoutSettings>
</igDP:XamDataGrid>
CODE BEHIND:
void cm_ContextMenuOpening(object sender, ContextMenuEventArgs e)
DataRecordCellArea item = sender as DataRecordCellArea;
DataRecord dataRecord = item.Record;
ContextMenu cm = item.ContextMenu;
cm.Items.Clear();
<NEED TO ACCESS COLUMN INFO HERE>
Perfect! Thanks for the quick help.
Perhaps you can create the style for the CellValuePresenter instead of the DataRecordCellArea and this way your sender will be the CellValuePresenter which you have clicked on. It exposes Record and Field properties which will help you determine which cell was clicked.
