2349
Why is it so hard to set a grid to read-only and allow scrolling?
I have an editable grid with xamnumericeditor, xammaskededitors, etc.  I allow the users to fill out the info and once it's submitted, they cannot edit, but they should still be able to look at it.I have done everything that I can think of to set the xamdatagrid to a readonly state and even filtered through each cell to set the editor to read-only.  Now when I'm doing this, it does not allow scrolling.  Isn't there a simple property somewhere for this?  I have spent 8 hours on this so I'd appreciate some help please.
  • 69686
    I am attaching a sample showing one way to achieve this. Here is some code snippets from the sample:
    <Style TargetType="{x:Type igEditors:ValueEditor}" x:Key="style">
                        <Style.Triggers>
                            <DataTrigger Binding="{Binding Path=Tag}" Value="false">
                                <Setter Property="IsReadOnly" Value="True"/>
                                <Setter Property="BorderBrush" Value="LightGray"/>
                            </DataTrigger>
                        </Style.Triggers>
                    </Style>
    void xamDataGrid1_RecordUpdated(object sender, Infragistics.Windows.DataPresenter.Events.RecordUpdatedEventArgs e)
                DataRecord dr = e.Record as DataRecord;
                dr.Tag = false;
    XamDataGrid_ReadOnly.zip
