435
Disable dates using CalendarDateRange
Hi
I need some help here to write some XAML code, sorry for my ignorance.
I was able to disable Saturday and Sunday for XamDateTimeEditor control with the style property.
<igEditors:XamDateTimeEditor>
  <igEditors:XamDateTimeEditor.Resources>
    <Style TargetType="{x:Type igEditors:XamMonthCalendar}">
      <Setter Property="DisabledDaysOfWeek" Value="Saturday, Sunday" />
    </Style>
  </igEditors:XamDateTimeEditor.Resources>
</igEditors:XamDateTimeEditor>
 I am trying achieve similar line with the below code, setting the business rule driven Min and Max date for XamDateTimeEditor control using CalenderDateRange, I am getting error "The Property Setter 'DisabledDates' cannot be set because it does not have an accessible set accessor"
      <Setter Property="DisabledDates"  >
 <Setter.Value>
   <igEditors:XamMonthCalendar.DisabledDates>
     <igEditors:CalendarDateRange Start="01/01/1000" End="04/01/2010" />
          <igEditors:CalendarDateRange Start="04/27/2010" End="12/31/4712" />
   </igEditors:XamMonthCalendar.DisabledDates>
 </Setter.Value>
      </Setter>
    </Style>
I believe I got the syntax wrong here, I need some guidence what is the best way to have the dates appear disabled inte calender control comes as part of XamDateTimeEditor. I under stand, I still need to validate for the dates when use key in those dates outside the range specified above.
