using the outllokbar in xaml, this is no problem. Here is my example:
<igOB:OutlookBarGroup x:Name="FredTab"
LargeImage
="Images\addbk_24x24.png">
igOB:OutlookBarGroup>
How can i do this in code behind without the full path? This is what I have now:
ARC210Group.SmallImage =
new BitmapImage(new Uri(@"C:\Projects\CMDL NET\CMDL.MissionLoaderTool.Framework\Images\prefs_16x16.png", UriKind.RelativeOrAbsolute));
This works, but obviously I don't want the C:\Projects... path, I want a relative path.
This isn't specific to our elements but if you want to specify a Uri that is based upon a relative path then you would probably use the BaseUriHelper class to get the base uri for the usercontrol/window. So the construction of the Uri would look something like new Uri(BaseUriHelper.GetBaseUri(this), @"Images\addbk_24x24.png").
Forgot to say the prefs_16x16.png is in a Folder in the project, folder is named Images and the images is set to a Resource.
