200
StackedColumn not displaying all of the labels
I recently start using the wpf component, still in the learning fase:).
I want to make a stackedcolumn chart by databinding some data to it
It works, but i only see for the first serie the correct label the other series dont have any label.
the code i am using is all in c#, the xaml only consist of declaring the chart.
this
.stackedChart.Series.Clear();
this
.stackedChart.Axes.Clear();
this.stackedChart.View3D = true
var
persons = _totalTicketsPerPersonModel.TicketList.GroupBy(t => t.LineName).ToList();
foreach (var person in
persons)
Series serie = new Series
serie.ChartType =
ChartType
.StackedColumn;
serie.DataMapping =
"Label = Day; Value = NumberOfTickets"
serie.Label = person.Key;
ObservableCollection<TotalTicketsPerPersonModel.TicketData> col = new ObservableCollection<TotalTicketsPerPersonModel.TicketData
var
tmp = _totalTicketsPerPersonModel.TicketList.Where(l => l.LineName == person.Key).ToList();
foreach (var a in
tmp)
col.Add(a);
serie.DataSource = col;
this
.stackedChart.Series.Add(serie);
var axe = new Infragistics.Windows.Chart.Axis
axe.Label.Format =
"{0:MM-dd-yy}"
axe.AxisType = Infragistics.Windows.Chart.
AxisType
.PrimaryX;
axe.Label.FontFamily =
new FontFamily("Arial"
axe.Label.FontSize = 14.0;
axe.Label.Foreground = System.Windows.Media.
Brushes
.Black;
