I need to navigate from the TabItem Header to the TabItem´s content first control. What should I do?
Thanks.
I have linked you support ticket: CAS-45354-4STC12 to development issue: 30695. You'll be automatically updated when a Service Release containing the fixe is available for download from our website: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
You have to wait for the next hotfix. I'll see about getting a case created for you so you can be notified when the hotfix is available.
HI Alex, thanks for your quick replay.
I got both issues. First, the contained first control gots the focus before the TabItem Header. Second, I´m not able to focus the first contained element when the focus is in the Header, pressing TAB focus is moved to the next control, not ot the first contained control.
What should be the solution?
Pressing the Tab key should move from the tab header area into the content area of the control. There was a bug recently reported about this where the template wasn't set up properly so the header was getting focus after the content area but that will be addressed in the next hotfix. Is that the issue you are having?
