520
Scroll Tip in XamDataGrid
Consider I am having 10 fields, where my scrolloing mode is 'DeferredWithScrollTips'.
My primary field is 'FieldA' but I need to set IsScrollTipField property to 'FieldC' as the postion of 'FieldC' changes at runtime due to user preferences.
            if (this.FieldLayouts != null && this.FieldLayouts.Count > 0)
                foreach (Field field in this.FieldLayouts[0].Fields)
                    if (field.ActualPosition.Column == 0 && field.ActualPosition.Row == 0 && field.Visibility == Visibility.Visible)
                        field.IsScrollTipField = true;
                    else
                        field.IsScrollTipField = false;             //But this doesn't work for primary field....
This code sets FieldC's IsScrollTipField as true but FieldA's IsScrollTipField is also true and I am unable to make this false.
So in some rare cases I am getting 'FieldA' as scroll tip but this should not be the case.
Kindly guide me to solve this.
Thanks & Regards,
M. Arthi
