When I group by a date field, there are a few different date ranges that get grouped together. Inside the groups, though, the records are sorted by the first column, not the date column that I chose to group by. Also, clicking on the date column doesn't sort the records.
How can I sort the records inside the groups?
Hello Jason, We have been looking in to this issue and since the Express Edition is no longer supported we are not able to provide you a fix for this behavior.However note that this issue is fixed in all higher versions.Let me know is if you have any further questions.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Sorry, 9.1 was the last release for the express edition. However, as of now, we are still maintaining that version. I will enter a bug so this issue can get fixed in 9.1 so hopefully it will be available in a service release.
I forgot to mention I'm using the express edition, which appears stuck at 9.1. Are there plans to update it to 9.2?
Hi Jason,
I just tested this out and it looks like it was a bug that has already been fixed. However, I tested it with the latest service release of 9.2. It does not look like it was fixed in 9.1. Can you move to 9.2?
