250
Changing themes at runtime throws an exception
Whenever I change themes at runtime by changing the ThemeManager.CurrentTheme property I get a null reference exception (stack trace below). The first time I change it, it works fine, but every subsequent time it fails. Is there something more I need to be doing than just setting that property?
Also, even running the sample posted by Alex in this thread http://community.infragistics.com/forums/p/37459/224447.aspx I get an exception when I change the theme.
   at System.Windows.DeferredResourceReference.RemoveInflatedListener(ResourceReferenceExpression listener)
   at System.Windows.ResourceReferenceExpression.InvalidateCacheValue()
   at System.Windows.ResourceReferenceExpression.InvalidateExpressionValue(Object sender, EventArgs e)
   at System.Windows.TreeWalkHelper.InvalidateResourceReferences(DependencyObject d, ResourcesChangeInfo info)
   at System.Windows.TreeWalkHelper.OnResourcesChanged(DependencyObject d, ResourcesChangeInfo info, Boolean raiseResourceChangedEvent)
   at System.Windows.TreeWalkHelper.OnResourcesChangedCallback(DependencyObject d, ResourcesChangeInfo info)
   at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode)
   at System.Windows.TreeWalkHelper.InvalidateOnResourcesChange(FrameworkElement fe, FrameworkContentElement fce, ResourcesChangeInfo info
