139
RibbonWindowContentHost.Ribbon under UserControl
I wanted to switch from Window to XamRibbonWindow as you instructed.
in step 4 you write:
Declare tags for the RibbonWindowContentHost's Ribbon property within the tags for the RibbonWindowContentHost. You can now add XAML for a xamRibbon control inside these tags. ...
My problem is that in my main window, I use a
<ContentControl x:Name="MenuLocation" .../>
while in a code I enter a UserControl that contains the XamRibbon as a content.
The problem is that I can't enter the <igRibbon:RibbonWindowContentHost.Ribbon> not in the main window hence it's child is <ContentControl and not in the userControl hence it's parent is UserControl and not RibbonWindowContentHost.
How can it be solved?
