370
XamDataGrid ContextMenu Handler in MVVM
Hi, I have been struggling for a few days now to find an answer for these questions.
first, I need to a be able to select an item on right click on the XamDataGrid. I did hope that my XAML
for ContextMenu would do the trick and I saw that the item that is highlighted when I right click on the
row to get the ContextMenu I open, would set the SelectedItems property, but the bound property in
my ViewModel returns a null on this.
Next, I am trying to pass the Row on the XamDataGrid as the item to my ContextMenu (Command)
handler in my ViewModel which relates  to my effort on the previous point. I read numerous posts
about ContextMenu being not on the same Visual tree as the XamDataGrid itself, which is why the
property SelectedItems cannot be propogated to the Command. I even read that the SelectedItems
property on XamDataGrid is not aDependencyProperty which is why even upon binding it to a property
defined in the ViewModel, it wouldn't stick to it.
My goal is to pass the row values or the entire row of the XamDataGrid, when I right click on ContextMenu
to perform some action which needs these details in the CommandHandler in the ViewModel. How
can I achieve this?
I posted the code and my question even on stackoverflow here
http://stackoverflow.com/questions/3003583/using-mvvm-how-to-pass-selecteditems-of-a-xamdatagrid-as-parameter-to-the-comman
.  Any help is very much appreciated.
