I have a XamDataGrid that is bound to a collection. In the code behind, I add an item to the collection, which in turn updatesgrid. I want to then select the new item in the grid. The only way I have found that works is to enumerate through the REcords in the grid and compare an identifier. Then, I set the record's IsActive property to true. Seems like there should be something easier.
Another way would be to handle the InitializeRecord instead of iterating through the records. Please note that selecting a record is associated with IsSelected property or adding it in the SelectedItems.Records collection. isActive makes the record active.
