I have a requirement to subscribe for a particular data (say "Symbol") and display the updates received for the subscription.
I can see XamDataGrid,DataValueChanged event and some sample around "Data Value Histroy" in xamFeatureBrowser, however I have not used it before and need some simple steps as to how to go about it.
Any pointers would be appreciated.
Hi Alex,
Do you have any example on how to handle the property changed event of the underlying data source to get the updates. I need to track changes in my xamdatagrid on Add/Delete/Update. THe grid is bound to a ObserveableCollection<myClass> where my class does implement the InotifyPropertyChange interface.
Thanks. We are able to implement the requirements using the DataValueChangedNotificationsActive and ValueHistory entities described in the XamFeatureBrowser samples.
You can handle the CellUpdated event, which will be fired when a cell's value is updated. You can also handle the property changed event of your underlying data source and get the new updates from there.
