I am adding markers with procedural code. I am able to get the markers to look the way I want, except, I want them to appear to be floating with a shadow effect. I was thinking a bitmap effect for the marker would work, but there doesn't seem to be a way to do this...or is there?
The scene supports it.
Steve
sorry, but you can't specify which template to use, and not much contextual information is available inside the template. so i don't think this will be possible in the current version.
Can you specify which template to use? I have three different markers...It looks like it will be binding to the data type. If I were not able to assign the datatemplate, could I use data template triggers?
you can change the Template for Markers... try this
<Window x:Class="WpfApplication2.Window1"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:igCA="clr-namespace:Infragistics.Windows.Chart;assembly=Infragistics3.Wpf.Chart.v7.2"
xmlns:local="clr-namespace:WpfApplication2"
Title="Window1" Height="400" Width="400">
<Window.Resources>
<DataTemplate DataType="{x:Type igCA:MarkerTemplate}">
<Ellipse Stroke="{Binding Path=Stroke}" Fill="Red" Width="20" Height="20">
<Ellipse.BitmapEffect>
<DropShadowBitmapEffect />
</Ellipse.BitmapEffect>
</Ellipse>
</DataTemplate>
</Window.Resources>
<igCA:XamChart Height="300" Width="300">
<igCA:XamChart.Series>
<igCA:Series>
<igCA:Series.Marker>
<igCA:Marker UseDataTemplate="True" />
</igCA:Series.Marker>
<igCA:Series.DataPoints>
<igCA:DataPoint Value="1" />
<igCA:DataPoint Value="2" />
<igCA:DataPoint Value="3" />
</igCA:Series.DataPoints>
</igCA:Series>
</igCA:XamChart.Series>
</igCA:XamChart>
</Window>
