115
XamMap v2010.2
I have a shape ifle that has a map projection type PROJECTION["Lambert_Conformal_Conic"], the customer has several shape files of this projection type and does not want to change.  below is the information of this shape file then below that is the example that you give.  The first problem is   <igMap:ShapeFileReader.CoordinateSystem>  Im told that the CoordinateSystem is not part of the ShapeFileReader.  Thank You
PROJCS["NAD_1983_StatePlane_California_I_FIPS_0401_Feet",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980", 6378137.0, 298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PARAMETER["False_Easting",6561666.666666666],
PARAMETER["False_Northing",1640416.666666667],
PARAMETER["Central_Meridian",-122.0],
PARAMETER["Standard_Parallel_1",40.0],
PARAMETER["Standard_Parallel_2",41.66666666666666],
PARAMETER["Latitude_Of_Origin",39.33333333333334],
UNIT["Foot_US",0.3048006096012192]]
