95
XamDataGrid throws exception while loading Customization
I am getting a exception when I load grid Customization. Details are as follows -
It happens only when there is any Sorting information is saved in grid Customization information.
For instance when application is loaded for first time then grid shows all the records in it. I click on any of the Column to perform sort on that, and when application is closed I get the settings using SaveCustomization() method and I save it in database.
When second time the application is started I read the settings from database and apply it using LoadCustomizations() method. This method is executed perfectly fine and no exception is thrown but if i do F5 to continue then it throws following exception -
at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
   at System.Collections.Hashtable.set_Item(Object key, Object value)
   at Infragistics.Windows.Helpers.HashSet.Add(Object item)
   at Infragistics.Windows.Helpers.HashSet.AddItems(IEnumerable items)
   at Infragistics.Windows.Virtualization.RecyclingItemContainerGenerator.PlaceAllActiveContainersInLimbo(IEnumerable
itemsExpectedToBeGenerated)
   at Infragistics.Windows.Virtualization.RecyclingItemContainerGenerator.BeginGeneration(ScrollDirection scrollDirection,
IEnumerable itemsExpectedToBeGenerated)
   at Infragistics.Windows.Virtualization.RecyclingItemsPanel.BeginGeneration(ScrollDirection scrollDirection, IEnumerable
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache..ctor(GridViewPanelFlat panel, Boolean isVertical,
Size constraint, Int32 overallScrollPosition, ScrollDirection scrollDriection)
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.MeasureOverride(Size availableSize)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ItemsPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean
forceInfinityV)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at Infragistics.Windows.DataPresenter.RecordListControl.MeasureOverride(Size availableSize)
forceInfinityV)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
forceInfinityV)
forceInfinityV)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at Infragistics.Windows.DockManager.DockManagerPanel.MeasureOverride(Size availableSize)
   at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
   at System.Windows.Controls.Decorator.MeasureOverride(Size constraint)
   at System.Windows.Documents.AdornerDecorator.MeasureOverride(Size constraint)
forceInfinityV)
forceInfinityV)
   at System.Windows.Controls.Page.MeasureOverride(Size constraint)
forceInfinityV)
   at System.Windows.Window.MeasureOverrideHelper(Size constraint)
   at System.Windows.Window.MeasureOverride(Size availableSize)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.UIElement.UpdateLayout()
   at System.Windows.Interop.HwndSource.SetLayoutSize()
   at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
   at System.Windows.Interop.HwndSource.set_RootVisual(Visual value)
   at System.Windows.Window.SetRootVisual()
   at System.Windows.Window.SetupInitialState(Double requestedTop, Double requestedLeft, Double requestedWidth, Double
requestedHeight)
   at System.Windows.Window.CreateSourceWindowImpl()
   at System.Windows.Window.SafeCreateWindow()
   at System.Windows.Window.ShowHelper(Object booleanBox)
   at System.Windows.Window.Show()
   at System.Windows.Window.ShowDialog()
   at SunGard.PS.ExceptionHandling.PSExceptionDialogManager.ShowDialogInternal(String strWhatHappened, String
strHowUserAffected, String strWhatUserCanDo, String strMoreDetails, MessageBoxButtons Buttons, MessageBoxIcon Icon,
UserErrorDefaultButton DefaultButton)
   at SunGard.PS.ExceptionHandling.PSExceptionDialogManager.ShowDialog(String strWhatHappened, String HowUserAffected, String
WhatUserCanDo, String MoreDetails, String ExceptionMessage, MessageBoxButtons Buttons, MessageBoxIcon Icon,
   at  *********** (I can't disclose this trace because this is our own custom classes where we handle exception at application level) .
To me the problem seems to be with following Infragistics method - Infragistics.Windows.Helpers.HashSet.Add(Object item)
Somewhere the "item" is getting set to null and this is causing this issue.
And this issue occurs only when I save Sorting information in grid Customization in all other scenarios it works fine.
Any help in this regard will be appreciated.
