240
How to implement field visibility by trigger?
I'm using XamDataGrid. However, I have a problem.
I want to display data depending on program version.
my data has properties as follows
No, Name, Department, StaffID
I want to display when program version is 1.0
But, when program version is 2.0, StaffID field does not display
  • 69686
    You will not be able to bind the visibility of the field with a trigger, but you can set this manually in the FieldLayoutInitialize event of the XamDataGrid. You can also create and apply a new FieldLayout depending on the version.
